99 DII Bank 5 misfire
Old Mar 16, 2009 | 09:57 PM
DiscoNoisebox's Avatar
I spoke with my mechanic, and it turns out they had done the comp test, and it tested ok.. I didn't get the numbers, though. The heads were bench tested when the gaskets were replaced. I'll have to find out if they tested all cylinders, or just number 5. Regardless, I am having the leakdown test done this Thursday. I'll let you guys know how it turns out.
Thank You
Old Mar 22, 2009 | 12:00 PM
Unhappy SES still on
Well, my mechanic has tested compression, leakdown, and injectors. All are OK. Any ideas where to go from here?
Old Mar 22, 2009 | 01:59 PM
Have you had the coil packs tested?
Old Mar 22, 2009 | 02:28 PM
Yep. Coil packs have been tested.
Old Mar 22, 2009 | 03:12 PM
If everything tests out good then I have no idea.
Injectors test good?
Old Mar 22, 2009 | 03:57 PM
greg409's Avatar
I think it's unlikely but not impossible that you've got a bad plug or wire.
Did the mechanic test the injectors only by seeing if the engine started after the initial work?
If it were me, I'd pull that plug and inspect, make sure it's not black (would indicate you're getting fuel.
If it's not, switch the injector with one from another cyl. see if the misfire moves.
How does it idle? Smooth?
luck,greg
Old Mar 22, 2009 | 06:39 PM
Thumbs up
Plugs and wires are new. I believe they said they "pulsed" the injectors. Idle does seem a bit rough at times. If I recall correctly, the plug color was typical of one that has been burnin antifreeze...a whiteish color.
Old Apr 20, 2009 | 07:03 PM
Default Help?
If anyone is still paying attention, I still have not found a resolution here. Anyone?
Old Apr 20, 2009 | 08:53 PM
Send me your tele number.
robson
Feb 22, 2018 05:42 PM
pdowning6
May 12, 2012 10:30 AM
wediveaxa
Sep 23, 2010 07:12 AM
98roverguy
Sep 28, 2006 09:23 PM
