99 Disco 2 Light geen wires on ignition coil wires
I have searched everywhere trying to find out what the two light green wires are that are spliced into the Green/Brown and Green/Yellow wires on connectors 052 and 0156. They are Y'd into these two wires and I can't find the other ends.
The previous owner relocated the coils onto the fire wall and cut these two wires. I am having some issues with power during acceleration and I would like to reconnect these prior to wasting a bunch of time troubleshooting.
Any help is greatly appreciated.
On the schematic, those two wires from the coil packs go back to a single fuse on the inside fuse panel. Plus battery when ignition is hot. I have no idea what else he may have added, it does not show on power distribution drawings either. You could ohm them and see it if there is a load on them.
Your performance issues may not be related to this, as long as good 12 volts supplied to coils.
ShadowMerchantBC
07-03-2011 09:08 PM
b_woodroaster
11-05-2010 08:54 AM
CandiMan
08-06-2008 06:08 PM
