99 Disco 2 Light geen wires on ignition coil wires
Old Jul 12, 2012 | 03:01 PM
crumleyjc's Avatar
Default 99 Disco 2 Light geen wires on ignition coil wires
I have searched everywhere trying to find out what the two light green wires are that are spliced into the Green/Brown and Green/Yellow wires on connectors 052 and 0156. They are Y'd into these two wires and I can't find the other ends.
The previous owner relocated the coils onto the fire wall and cut these two wires. I am having some issues with power during acceleration and I would like to reconnect these prior to wasting a bunch of time troubleshooting.
Any help is greatly appreciated.
Old Jul 12, 2012 | 04:02 PM
On the schematic, those two wires from the coil packs go back to a single fuse on the inside fuse panel. Plus battery when ignition is hot. I have no idea what else he may have added, it does not show on power distribution drawings either. You could ohm them and see it if there is a load on them.
Your performance issues may not be related to this, as long as good 12 volts supplied to coils.
File Type: pdf
Old Jul 13, 2012 | 01:57 PM
crumleyjc's Avatar
Thanks for the reply. No info on the green wires anywhere. I did find one of the problems. The gasket on the fuel pump was down around the stainless steel straps. I reinstalled it correctly and the power issue mostly went away. I think I may need to do a little more testing on the MAF.
trialrun
Nov 11, 2014 08:41 AM
ShadowMerchantBC
Jul 3, 2011 09:08 PM
b_woodroaster
Nov 5, 2010 08:54 AM
GoldDiscoII
Jan 31, 2009 09:09 PM
CandiMan
Aug 6, 2008 06:08 PM
