'99 Disco II Brake Pads
Old Jan 24, 2007 | 08:10 PM
sarahr's Avatar
4th Gear
Default '99 Disco II Brake Pads
Gang - It's almost time for my front brakes to get new pads. I got quoted $600 (at the dealership, of course) yesterday for this job, and laughed in the girl's face. There's no way I'd pay that kind of ridiculous money.
Is this something we could do on our own? I do have a trustworthy independent shop, but brake pads seem like they are doable by us.
Any advice or stories on how to go about it?
Thanks.
Old Jan 25, 2007 | 11:12 AM
Default RE: '99 Disco II Brake Pads
Order some brake pads from Atlantic British or any other rover supplier and put the pads on yourself, it is easy to do.
Mike
Old Jan 25, 2007 | 11:33 AM
sarahr's Avatar
4th Gear
Thanks. Looks like a nice set can be had for $100 there. Is there a good site online that has pics of projects like this? I don't own a repair manual (which one would people recommend for a gal on a budget, by the way)?
Thanks.
Old Jan 25, 2007 | 04:20 PM
geoman's Avatar
Normally --- the pads and rotors are changed out at the same time. This is because the brake rotors wear at the same time as the pads, with resulting grooves in the rotors. If you fit new pads to grooved rotors --- you GREATLY shorten the life of the new pads. The oldrotors are not "turned" or machined as in days of old. Check out this link for my price on a front brake kit for your Disco.
http://www.eurotekapg.com/brkc.html
Also feel free to call the number on the web-site for technical assistance.
regards,
Geoman
Old Jan 25, 2007 | 04:38 PM
XBlade's Avatar
ORIGINAL: geoman
Why do you say the rotors can't be "turned"?
X
Old Jan 25, 2007 | 04:43 PM
JBRIII's Avatar
because they are thin to beging with and when you turn them, you go below there minium thickness on the front of 23mm and 11 mm for the rear
Old Jan 25, 2007 | 04:45 PM
geoman's Avatar
The main reason is that the wear pattern cannot be removed without the rotor falling below the minimum thickness value. No machine shop will machine a rotor below this value unless they like lawsuits. And in some cases the rotor will have localized "hot spots" which also require more material to be removed to get "shudder-free" performance. The replacement rotors and padsI offer are good for 20-40K of usage ---depending on the driving habits of the owner.
geoman
www.eurotekapg.com
Old Feb 25, 2007 | 01:38 PM
bookerbr's Avatar
You can purchase a service manual on cd, pdf file. Found on ebay for $3.99. Then print out whatever pages you need for that project.
Florida04RR
Mar 10, 2010 06:09 AM
ljdiscovery
Jan 17, 2009 01:35 PM
CincyRover
May 28, 2008 07:20 AM
sparky
Apr 13, 2008 09:13 AM
ashdisco
Sep 29, 2006 03:40 PM
