99 Disco II Trans Temp Light
Old Apr 28, 2011 | 09:12 PM
All automatic transmissions have a pump for the trans fluid.
See my other reply.
Old Apr 28, 2011 | 09:55 PM
tbesselman's Avatar
So I understand there are two sensors one on the cooler (radiator) and one on the drivers side of the tran case - I assume the one I change is the one on the tran case with the two wire connectors? Sorry to be a PIA - I don't have much transmission experience
Old Apr 28, 2011 | 10:04 PM
DarylJ's Avatar
Originally Posted by tbesselman
So do the disco II's have an oil pump for the transmission fluid that could have gone bad that may be the problem....
Automatic transmissions work on hydraulic pressure. The "pump" is the torque converter (this is not Rover specific). Things with oil coolers just route some of the fluid outside of the trans through a cooler and back in again. No other pumps are required past what makes the transmission operate.
Sunny side auto
Apr 10, 2011 08:00 AM
ch4699
Feb 5, 2008 01:27 PM
bamarover
May 21, 2007 08:24 AM
bamarover
May 18, 2007 09:33 PM
97DISCOIDAHO
Sep 9, 2006 11:04 AM
