99 discovery heat and air not working
Old May 27, 2010 | 04:46 AM
  #21
rob99rst's Avatar
car battery is just fine starts every time. 1000cca
Old Nov 9, 2010 | 03:14 PM
  #22
v13simonjester's Avatar
I had this problem on my 1999 Disco II. I found that the voltage was present through the exterior fusebox. I measured the voltage at the Fuse 7 contacts on the interior fusebox and found that the voltage was low. I removed the fusebox from underneath the dashboard (with the addition of a few scratches to my hands) and opened the fusebox. I found that the problem was caused by a cold solder joint in the middle of one of the PC boards. A hot iron and some solder fixed this right up.
Old Nov 9, 2010 | 03:17 PM
  #23
so, you have had it tested and when running it is between 13.6 and 14.4 volts? Starting fine doesn't tell the condition of your electrical system.
Summer681
Dec 5, 2023 07:21 AM
Leni
Aug 18, 2014 10:22 AM
jbriggs
25
Nov 2, 2012 10:08 PM
Miwo
May 4, 2011 08:40 AM
umoms
Apr 3, 2008 06:22 PM
