'99 Discovery Series I power drain problem
Old Jan 12, 2009 | 11:24 AM
Default RE: UPDATE:
There was a guy on here last winter with the same issue as you, same problem, belt was routed wrong.
It DOES make a difference, to bad neither shop will admit that they are idiots.
I wouldnt be using either of them again.
And I would call the Better Buisness Buaure.
Old Jan 12, 2009 | 11:30 AM
wick_60010's Avatar
Default RE: UPDATE:
Despite the fact that I'm not a mechanic, it would seem logical to me that a belt which goes AROUND a pulley rather than just TOUCHINGthe pulley would have a different impact. The folks at Land Rover (except for the first tech that looked at it this morning) couldn't understand that concept.
Old Jan 12, 2009 | 11:32 AM
Default RE: UPDATE:
Well now you know where to turn to first LOL.
Best of continued luck to you.
If you get the check engine light read at AutoZOne and write down the fault codes we can help you with that too.
Old Jan 12, 2009 | 11:37 AM
AK Rover's Avatar
Default RE: UPDATE:
If the belt is routed wrong then the tensioner is not able to put proper tension on the belt. If I can figure that one out any mechanic should be able to. Did you make sure the mechanics knew what a belt was?
I have to agree with Spike, time to find a new mechanic.
We generally recommend avoiding the dealer because they'll rip you off. Sounds like in your case the dealer mechanics are idiots as well as crooks.
Get your codes read and let us know so we can help you out with the new codes.
Old Jan 12, 2009 | 11:38 AM
wick_60010's Avatar
Default RE: UPDATE:
Will do. You guys are sensational on here! Last year I had that issue where the rear windows became unoperable, and after doing everything I could think of, I turned to this board. I was given instructions on removing the glove box and taking out the circuit board, as it most likely had a bad solder. I couldn't believe my eyes when it was EXACTLY as had been explained to me. Who would have EVER thought of that? Seriously, you guys are unbelievable!
Old Jan 12, 2009 | 01:00 PM
wick_60010's Avatar
Default RE: UPDATE:
Ran out to Autozone and the following two codes were returned when the "Check Engine" light was checked out:
P0130 - O2 Sensor
P0560 - System Voltage
The truck seems to be running perfectly. The light came on this morning on the way to the dealer, meaning BEFORE they re-routed the belt.
Old Jan 12, 2009 | 01:08 PM
Default RE: UPDATE:
Ok, now that you have gotten your codes read if you start a nre thread it will be easier for us to help you.
It gets confusing with two problems under one thread, ya know?
Old Jan 12, 2009 | 01:21 PM
wick_60010's Avatar
Default RE: UPDATE:
Posted the new issue ("Check Engine" light) to a new thread titled, "'99 Discovery Series I fault code meaning? "
Bob5215
Oct 28, 2013 02:36 PM
groomer
Mar 29, 2010 12:31 PM
AlexERAsDisco
Dec 16, 2006 03:18 PM
McDougal
May 5, 2006 06:04 PM
95roverV8i
Mar 26, 2006 03:29 PM
