ABS amigo codes - next steps?
Editing this post but still need some guidance. Got the ABS Amigo new today. Ran codes a couple of times this afternoon. The Three Amigos remained on the first three times I used the device. On the way home from work the amigos were no longer lit up. Here's my latest read out of the codes. Any suggestions on what to tackle first would be greatly appreicated
Thanks!
Matt
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
017:ECU internal valve relay bad
045:Rear Left sensor output low
Rear Left Sensor Bad Output
<-END Faults
Active Faults:
022:ECU Gnd or Reference Gnd bad
Logged Faults:
None
<-END Faults
Thanks!
Matt
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
None
<-END Faults
