ABS Amigo Mystery
Old Mar 30, 2017 | 12:20 PM
coors's Avatar
Default ABS Amigo Mystery
Here's a New one for me, anyway.
Three Amigos randomly appeared this morning. Just speculating, but I believe it was triggered by a rough road occurrence. I'm lifted +3.5" w/ no rear sways.
I plugged in ABS Amigo cleared the Amigos.
When I pulled the data from the Amigo this is what I received...
I was surprised Not to see a logged fault.
|* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *|
|* Welcome to RSW Solutions *|
|* Version V1.1 *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Old Mar 30, 2017 | 12:29 PM
coors's Avatar
A little further review, maybe this relates to me...
I did install aftermarket ceramics.
RSW Solutions
"A worn brake pad or even some new non-Land Rover Brake pads can set up a resonance vibration in the wheel hub. This vibration can interfere with the ABS sensor signal. When the ABS sensor signal is interrupted an ABS wheel speed sensor fault can be logged."
Old Apr 13, 2017 | 03:24 PM
Philip Schoenauer's Avatar
I also have a 3 amigos mystery. Here is the run down: I replaced All wheel sensors (full wire), all 4 hubs, new SLABS, rebuilt shuttle valve, and rotors and pads. I have been dealing with this nightmare for years. I am finally down to the 3 amigos staying off but.......if i start driving the rear right ABS T/C engages like that one tire is slipping. So i bought another new hub. no fix. so i went and measured the tire circumference of all my tires. (maybe unusually tread ware) nope all tires where exactly the same or within 1/8", which on a 33" tire that is not much. I am at witts end and running out of ideas as to what it could be.
My next shot in the dark is to replace all brakes calipers and to buy EBC brakes and rotors. I will start with the rear calipers first.
PLEASE HELP before i keep dumping money into something i don't need.
lipadj46
Apr 13, 2017 04:51 PM
yuenie
Jan 13, 2010 05:37 PM
Princess
Jul 4, 2009 12:24 PM
Malafax_Dand
Mar 30, 2009 06:31 PM
