ABS Amigo results...
Old Jun 25, 2015 | 09:05 AM
jamestfl's Avatar
Default ABS Amigo results...
so here are the results of the ABS Amigo reading from the truck...
|* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *|
|* Welcome to RSW Solutions *|
|* Version V1.1 *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
046:Front Left sensor output low
Front Left Sensor Bad Output
<-END Faults
Active Faults:
114:Shuttle Valve Electric Failure
Logged Faults:
020:No batt supply voltage
021:Engine PWM signal bad
023:Gear info not valid
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
<-END Faults
who can help me decipher what is relevant and what isn't from that? should I just be focusing on the left front sensor? lube it? replace it?
your help is appreciated!
Old Jun 25, 2015 | 09:56 AM
dusty1's Avatar
are your 3a on?
if that sensor output 046 is yours......it could be bad hub or just sensor or connection
Old Jun 25, 2015 | 10:16 AM
drowssap's Avatar
sensor output low; is what i got when my hub was bad
Old Jun 25, 2015 | 12:09 PM
jamestfl's Avatar
well, they were on. then I Amigo'd them and they were off. then I drove about a block and got the 3 bells, and the Amigos rode back into town.
what's the 'triage' here? lube the sensor/hub thingy - - replace sensor/wire - - replace hub? that about the look of it?
Old Jun 25, 2015 | 12:20 PM
drowssap's Avatar
checking the hubs for play would not be a bad place to start
Old Jun 25, 2015 | 12:42 PM
OffroadFrance's Avatar
Originally Posted by dusty1
are your 3a on?
X1 seems like the sensor, connection or hub is screwed up. If it's the hub remember the new sensor comes as part of the hub bearing kit.
In the past it would appear that the ABS system has suffered a shed load of coded faults although not currently applicable ................ I think/hope.
Old Jun 25, 2015 | 12:46 PM
dusty1's Avatar
That thing gets shipped around and has seen a few different discos and their issues
Old Jun 25, 2015 | 12:52 PM
Yep, you're right, never crossed my mind it could be from the previous punters readings.
Old Jun 25, 2015 | 12:55 PM
OEMPartHaus.com's Avatar
Former Sponsor
Mine has a lot to say.....
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
014:Pump fail pump sticking
022:ECU Gnd or Reference Gnd bad
033:Front Left out valve open circuit
035:Rear Right out valve open circuit
040:Pump relay open circuit
044:Front Right sensor output low
045:Rear Left sensor output low
047:Rear Right sensor output low
Front Right Sensor Bad Output
<-END Faults
Active Faults:
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Old Jun 25, 2015 | 03:19 PM
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Hmmm, makes me wonder how accurate these things are sometimes or whether they are just reading true active faults or possible generic faults.
microbc
Feb 28, 2013 02:47 PM
seaosrover
Oct 23, 2010 01:48 AM
bosshogt
Sep 18, 2010 01:16 PM
Princess
Jul 4, 2009 12:24 PM
