ABS Downhill and TC Light are on
Old Oct 17, 2007 | 06:54 PM
tkeagle's Avatar
3rd Gear
Default ABS Downhill and TC Light are on
All three of these lights came on at the same time. Anyone have a clue what they are trying to tell me????
Thanks!
Old Oct 17, 2007 | 08:16 PM
Default RE: ABS Downhill and TC Light are on
You might want to do a search, there are hundred of posts with the same questions that have been answered in just the last year, then if you still have a question I'll be glad to help.
Old Oct 17, 2007 | 10:08 PM
Camdisco24's Avatar
Its called the Three Amigos, that might help your search a little like mike recommended. Tons of stuff on here about that.
Old Oct 17, 2007 | 10:58 PM
NWDiscoRover2004's Avatar
yup, you know you're a mamber of the Land Rover club when you get the three lights of death. Mine happens everytime the ABS kicks on which happens a lot while pulling my boat.
Old Oct 18, 2007 | 08:02 AM
Mandrake's Avatar
4th Gear
Hi,
I am a new member of the LR Club (Got the 3 lights on, 2001 Disco, 155K km).If the ABS ECU senses a failure even for a small period of time, Does it disable all the related functions? Or it will continue tofunction normally once the errors got cleared, butleaving the warning signals on? How I can check the functionality of ABC, TC and HDC in a user’s point of view?
Thanks in Advance.
Mandrake
Old Oct 18, 2007 | 08:45 AM
The test would be to try braking hard on a loose surface, if you feel the ABS pulsate thru the brake pedal, then you know that is working. The other two functions are tested on a loose hill of a trail. That is about the only way to know for sure.
If you can then find a shop that will scan your system for faults, write down the code numbers and ask to have the faults cleared. Most likely they won't come on again, if the same one comes on again then you will need to look at a possible part replacement.
Old Oct 18, 2007 | 10:18 AM
ajh's Avatar
ajh
It takes more than one occurance before it disables the system. I was seeing the lights come on when I had a detroit locker in the rear and it was not behaving well and caused shuddering in the system and that brought it out. If you're getting it when braking towing you may want to consider another type of brake pads. Does your trailer have a surge brake? I could see that causing it... if it does consider going to a brake controller and hydraulic brakes for a more smooth braking with the load.
Old Oct 20, 2007 | 08:34 AM
Mandrake's Avatar
4th Gear
It was a rear left sensor intermittent failure. My workshop guy was kind enough to scan the code and reset the system for free.
khandrh
Jun 21, 2011 12:24 PM
dbh
Dec 20, 2009 10:25 PM
khandrh
May 21, 2009 07:27 PM
faugsu
Dec 13, 2006 10:25 PM
discodream99
Nov 10, 2005 12:54 AM
