(ABS) (ETC) (HDC) lights after hub change!
My mother has a 2001 Land Rover Discovery SE and just last week she had her rear passenger side hub (part # tay100050) and brakes changed. After they were changed the (ABS) (ETC) (HDC) lights on the dash lit up. so after a little reading I found that "faults with the etc system will invariably cause the hill descent control warning light to illuminate also and in most cases cause the abs brake system lights to illimunate". the abs sensor was taken from the old hub and put on the new hub to see if the sensor from the new hub was defective but that wasnt the case. Has anyone run into this problem before, or could possibly point me in the right direction to solve this problem. Thanks in advance!
RE: (ABS) (ETC) (HDC) lights after hub change!
A TIB is a technicle bulletin by land rover, The overlay eliminates the complete wiring harness between the ABS control module behind the glove box to the sender (hardwired onto the new harness) Its one size fits all and costs around 90 bucks
Alan Phillips
11-19-2018 03:27 PM
06Range
05-08-2013 09:01 PM
