(ABS) (ETC) (HDC) lights after hub change!
Old Jun 3, 2006 | 07:30 PM
electricboost's Avatar
3rd Gear
Default (ABS) (ETC) (HDC) lights after hub change!
My mother has a 2001 Land Rover Discovery SE and just last week she had her rear passenger side hub (part # tay100050) and brakes changed. After they were changed the (ABS) (ETC) (HDC) lights on the dash lit up. so after a little reading I found that "faults with the etc system will invariably cause the hill descent control warning light to illuminate also and in most cases cause the abs brake system lights to illimunate". the abs sensor was taken from the old hub and put on the new hub to see if the sensor from the new hub was defective but that wasnt the case. Has anyone run into this problem before, or could possibly point me in the right direction to solve this problem. Thanks in advance!
Old Jun 4, 2006 | 03:06 AM
Bait's Avatar
Default RE: (ABS) (ETC) (HDC) lights after hub change!
TIB on this issue. Overlay harness may fix. Why was the hub replaced in the first place?
Old Jun 4, 2006 | 04:20 AM
3rd Gear
hub was leaking so it was replaced, btw what does TIB mean?
Old Jun 7, 2006 | 06:14 AM
rinmud's Avatar
A TIB is a technicle bulletin by land rover, The overlay eliminates the complete wiring harness between the ABS control module behind the glove box to the sender (hardwired onto the new harness) Its one size fits all and costs around 90 bucks
Alan Phillips
Nov 19, 2018 03:27 PM
ssakayeda
Jan 8, 2015 10:25 PM
VCFZ
Dec 11, 2014 11:58 PM
06Range
May 8, 2013 09:01 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
