ABS Extension Question
Old 08-04-2012 | 07:45 PM
willrok13's Avatar
Default ABS Extension Question
Hi guys,
Quick question about the SlickRock Fab ABS Extensions. Do they just plug in between the existing ABS wires at the hub and frame, or can I remove the connector from the hub/caliper end and totally replace the wire going from the frame to the hub? I thought the hub sensor was permanently installed, but the SlickRock wires are REALLY long and I'm not sure what to do with the excess. Thanks for the help.
Here's the website: SlickRock Fabrication -- EE -- Expedition Exchange Incorporated
Old 08-04-2012 | 09:56 PM
ebg18t's Avatar
Just plug in. But they re bout 10" longer than I needed.Mine are just looped and zip tied.
Old 08-04-2012 | 10:57 PM
willrok13's Avatar
Thanks for the response. So I don't remove the wire from the hub? I'm going to have a lot extra lol
Old 08-05-2012 | 08:02 AM
ebg18t's Avatar
Yep jut a tone of extra. I wish someone made a set that was half the length.
Old 08-05-2012 | 08:13 AM
Don't waste your money buying a set of extensions when all that is necessary for a 2" to 3" lift is unplug them and reroute them for better articulation.
I have a near 3" lift and never replaced mine although it is good to replace the rubber brake hoses with stainless steel extensions.
galchutt81 (04-10-2016)
Old 08-05-2012 | 12:04 PM
willrok13's Avatar
Thanks, Mike. I rerouted the lines and then jacked up the truck until the +2" shocks topped out. The wires held but are pretty tight. Would you recommend releasing some of the abs wire from the harness on top of the frame? The wires are bound in some plastic conduit and I think cutting it out may give me another inch or so. What do you mean when you say "re-route" the wires? Just unplugging them from their holders? Or totally re-routing over the frame? Thanks.
Old 08-05-2012 | 01:29 PM
I would probably do that before buying a long set of extensions that will then need to be looped to keep them out of the way.
Old 08-05-2012 | 04:53 PM
ebg18t's Avatar
Unfortunately at 4.5-5" of lift I had no choice. Also required 6deg castor correction Radius arms and other misc crap.
RoveringAgain
11-08-2009 03:51 PM
RoveringAgain
06-10-2009 03:09 PM
sna77
12-19-2008 10:58 AM
veriluxxx
06-01-2007 09:16 PM
was8v
03-03-2007 08:42 PM
