ABS Extension Question
Old Aug 4, 2012 | 06:45 PM
willrok13's Avatar
Default ABS Extension Question
Hi guys,
Quick question about the SlickRock Fab ABS Extensions. Do they just plug in between the existing ABS wires at the hub and frame, or can I remove the connector from the hub/caliper end and totally replace the wire going from the frame to the hub? I thought the hub sensor was permanently installed, but the SlickRock wires are REALLY long and I'm not sure what to do with the excess. Thanks for the help.
Here's the website: SlickRock Fabrication -- EE -- Expedition Exchange Incorporated
Old Aug 4, 2012 | 08:56 PM
ebg18t's Avatar
Just plug in. But they re bout 10" longer than I needed.Mine are just looped and zip tied.
Old Aug 4, 2012 | 09:57 PM
willrok13's Avatar
Thanks for the response. So I don't remove the wire from the hub? I'm going to have a lot extra lol
Old Aug 5, 2012 | 07:02 AM
ebg18t's Avatar
Yep jut a tone of extra. I wish someone made a set that was half the length.
Old Aug 5, 2012 | 07:13 AM
Don't waste your money buying a set of extensions when all that is necessary for a 2" to 3" lift is unplug them and reroute them for better articulation.
I have a near 3" lift and never replaced mine although it is good to replace the rubber brake hoses with stainless steel extensions.
Old Aug 5, 2012 | 11:04 AM
willrok13's Avatar
Thanks, Mike. I rerouted the lines and then jacked up the truck until the +2" shocks topped out. The wires held but are pretty tight. Would you recommend releasing some of the abs wire from the harness on top of the frame? The wires are bound in some plastic conduit and I think cutting it out may give me another inch or so. What do you mean when you say "re-route" the wires? Just unplugging them from their holders? Or totally re-routing over the frame? Thanks.
Old Aug 5, 2012 | 12:29 PM
I would probably do that before buying a long set of extensions that will then need to be looped to keep them out of the way.
Old Aug 5, 2012 | 03:53 PM
ebg18t's Avatar
Unfortunately at 4.5-5" of lift I had no choice. Also required 6deg castor correction Radius arms and other misc crap.
RoveringAgain
Nov 8, 2009 02:51 PM
RoveringAgain
Jun 10, 2009 02:09 PM
sna77
Dec 19, 2008 09:58 AM
veriluxxx
Jun 1, 2007 08:16 PM
was8v
Mar 3, 2007 07:42 PM
