ABS fault...any idea what this means?
Old Jan 4, 2020 | 10:50 AM
Brandon318's Avatar
Default ABS fault...any idea what this means?
Help decipher... the red brake light is on, but no 3 amigos.
Old Jan 4, 2020 | 11:35 AM
coors's Avatar
Open the hood and check your brake fluid reservoir. The light may be an indication your brake fluid is low.
Old Jan 4, 2020 | 12:41 PM
Best4x4's Avatar
Or the ebrake switch
Old Jan 4, 2020 | 06:08 PM
mln01's Avatar
As the others said, the only two faults that cause the BRAKE light to illuminate without the Three Amigos are a low brake fluid level and the parking brake being not fully released. It's in the Owner's Handbook and in the RAVE. It has nothing to do with the ABS system.
Old Jan 4, 2020 | 09:14 PM
Brandon318's Avatar
...sheepishly I admit it was the simplest of simple things... low fluid. I feel so dumb. I literally rebuilt the calipers and bled the entire system late last night, and then in the euphoria of finishing up, forgot to top off the fluid. It only needed about a 1/2 inch to extinguish the light. Meh. Idiot.
Old Jan 5, 2020 | 07:10 AM
greisinb's Avatar
Easy to fix problems are the best problems!
Old Jan 5, 2020 | 02:09 PM
Richard Gallant's Avatar
@Brandon318 I think we have all done something similar at some point.
sorbet35
Mar 20, 2023 09:13 AM
zuke
Jan 11, 2018 01:05 PM
Indiana Jones
Mar 9, 2013 01:53 AM
whatmeworry?
Jul 21, 2009 08:13 AM
