3 amigos and a brake light
Old May 23, 2013 | 06:34 PM
sorbet35's Avatar
Default 3 amigos and a brake light
Yes they finally came to pay a visit to my 04 disco.The brake light is also illuminating,im assuming its just part of the abs warning system,is that correct or should i be concerned?
Old May 24, 2013 | 05:50 AM
drowssap's Avatar
Should you be concerned if your brake light comes on?
Old May 24, 2013 | 06:27 AM
No, the brake light only comes on if your brake fluid is low or your e-brake is not totally released.
Old May 24, 2013 | 11:35 AM
sorbet35's Avatar
thanks guys for the reply.looking into it now
Old Mar 14, 2023 | 03:10 PM
doma's Avatar
4th Gear
Actually RAVE says brake light is not on only for brake fluid or handbrake. See this: https://landroverforums.com/forum/di...e2/#post858852.
Old Mar 14, 2023 | 04:20 PM
XRAD's Avatar
Wow! this is a real resurrection of a long dead and moderately dead thread. But, a good point is made. Not just that the third option turns on the light, that it may be a fault in the SLABS unit triggering the light. Nice to see the research done and posting of RAVE E diagrams!
Old Mar 14, 2023 | 07:29 PM
Extinct's Avatar
Red brake light with 3 amigos, handbrake off, and full reservoir means a hard wheel sensor fault ie zero/no signal versus intermittent signal.
Old Mar 15, 2023 | 07:02 PM
gulfstream69xr7's Avatar
This.
When my front sensor was bad I had the brake light on as well as the 3 amigos. All went away when I replaced the hub.
Old Mar 20, 2023 | 09:13 AM
doma's Avatar
4th Gear
I Fixed mine. Further update here:
https://landroverforums.com/forum/di...e2/#post859577
cappedup
Jan 1, 2023 01:57 PM
Brandon318
Jan 5, 2020 02:09 PM
zuke
Jan 11, 2018 01:05 PM
JaySun
Mar 10, 2014 03:51 PM
Indiana Jones
Mar 9, 2013 01:53 AM
