Abs Fault, Rear Right Outlet Valve Circuit Open
Hello, I have a 2003 Land Rover discovery that is throwing a rear right outlet valve circuit open code on my nanocom. My dashboard is now lit up like a Christmas tree with TC, ABS, hill decent you name it haha. It started off by only coming on every once in a while and shutting off when I restarted the car. Now it is stuck on after hitting a nice pothole. I have not addressed this fault yet as I have been busy but I was just curious if anybody has any useful information on what could cause this code besides something as simple as a loose connection or faulty sensor because I have read a number of different things with no clear answer. Thanks.
ABS errors often show up in strange ways. It looks like you have a Nanocom so it should be picking them up accurately, but the hard bump causing the error to set in place makes me think that a wheel sensor could also be contributing. I would start with the shuttle valves (and do Option B while that is being fixed) but I wouldn't be surprised if you need a wheel sensor replacement as well.
Cpashley1 (10-15-2024)
