ABS Frustration
ABS Frustration
OK cleared and fixed the 3 amigos with the shuttle valve MOD and that fixed it other than a ground issue, chased grounds and fixed batter ground cable.All seemed good and all fixed. replaced battery and now the ABS and TC lights are back and just keep pulling ecu ground or reference ground fault.
so I ohmed out pin 8 on c0501 and get what looks like an open circuit on the meter. But my color of wire not match what other say it should. but it is a black wire on pin 8 of the connector. So not sure if i on the right wire.
Connector c0500 reads correctly on the meter for ohms.
So am I on the right wire for this ?
Frustrated as heck right now
Spencerfitch
12-27-2010 01:55 AM
