ABS Light - Discovery 2
Old Aug 13, 2022 | 09:36 PM
jnieves2019's Avatar
5th Gear
Default ABS Light - Discovery 2
'I replaced all 4 sensors, shuttle valve bypass, replace entire ABS pump with another and still ABS light will not go off. Any suggestions as to what I should be checking next or where the malfunction might be located?
Thanks,
Old Aug 13, 2022 | 10:19 PM
mln01's Avatar
Have you had the ABS codes read? I'm guessing no, since you've thrown that many parts at the problem. Is it just the ABS light that remains on, or are the other two amigos on also (Hill Descent and Traction Control).
It's well known that wheel speed sensor faults are often triggered by faulty connectors rather than the sensors themselves.
Old Aug 14, 2022 | 05:16 AM
mollusc's Avatar
In addition to what mln01 has said, the ABS light often won't go out on its own even if the problem causing it has been corrected. You usually need to clear the codes by hand.
Old Aug 14, 2022 | 08:06 AM
JoshD's Avatar
Where are you located? If you are in the San Antonio/Austin area I can read and reset the ABS codes for you. I was able to fix mine with a 100.00 code reader and a 28 dollar ABS sensor.
Old Aug 14, 2022 | 03:11 PM
mln01's Avatar
Also, the ABS light does not go off even if the faults have been corrected and the codes cleared until the truck reaches a specified speed (don't recall what that is; maybe 10 mph) so that the SLABS computer can verify signals coming from all four wheel speed sensors.
Old Aug 18, 2022 | 09:25 AM
samd612's Avatar
Hey Josh, what code reader did you buy to clear them? I have a 400$ launch code reader and it wouldn’t even get into the abs controller…. Found the PF abs speed sensor rubbed through
Old Aug 18, 2022 | 12:48 PM
JoshD's Avatar
I got the icarsoft i930 from Amazon. It reads and clears ABS codes and Engine codes along with other stuff I don't know how to use. lol.
Old Aug 18, 2022 | 07:45 PM
JohnZo's Avatar
My mechanic has an OBD scanner that can show the sensor pulses as you roll in or out of the driveway. The ABS system has its own set of codes.
Old Aug 19, 2022 | 03:24 AM
frostythor's Avatar
This may not be the correct solution but it could turn your ABS light off
Old Aug 19, 2022 | 04:20 AM
frostythor's Avatar
Hi again having watched this video I now see why they jump the wire as this video shows the fault can be a bad contact on the 2 pin connecter and by rewiring it you bypass the 2 pin connector worth a watch, also note the new bit he installed at $800, were doing the top video, it peanuts maybe $2....
wyrdvans
Jul 15, 2013 06:10 AM
LeeH0615
Mar 5, 2012 02:27 PM
Lee97Disco1
Dec 8, 2010 07:14 PM
hsipromo
Jan 30, 2010 09:10 PM
tweakrover
Sep 26, 2009 12:06 PM
