ABS Light while braking.
Old Jul 14, 2013 | 12:25 PM
wyrdvans's Avatar
Default ABS Light while braking.
I just finished up the SVS Option B fix. Before the fix my ABS light would come on when I would brake hard enough to get the ABS to work. Occasionally I would also get the three amigos but they usually when away with a power cycle. Now since the fix, when I brake hard the ABS light doesn't come on but I can tell the ABS is working. Is that normal? Was the ABS light indicating an issue with the ABS and not that the ABS was triggered as I assumed?
Old Jul 14, 2013 | 07:11 PM
You need to find someone with a 3 amigo type scanner to read the actual fault codes so you don't have to guess.
Old Jul 14, 2013 | 11:40 PM
wyrdvans's Avatar
I did. That's why I fixed it.
My question was about the abs light. Is it supposed to illuminate when it's active or only when there's a fault when active?
Old Jul 15, 2013 | 12:26 AM
Activates at bulb check (start up) and when there is a fault in the system. From page 68 of the owner manual.
Old Jul 15, 2013 | 06:10 AM
wyrdvans's Avatar
Thanks. I didn't think of checking the docs until after I submitted the post. Ended up finding it in the workshop manual when I found some time to read through it.
RoverPete
Sep 22, 2013 06:27 PM
CrimsonRavyn
Feb 26, 2012 09:40 PM
Redmel76
Jul 28, 2011 06:40 PM
forzabarca
Feb 13, 2010 08:33 PM
Money Pit
Freelander
Nov 2, 2008 10:45 AM
