ABS lights on after brake line repairs.
Old 04-04-2008, 07:12 AM
Default RE: ABS lights on after brake line repairs.
ORIGINAL: CandiMan
ORIGINAL: Disco Mike
On a D1, if the single ABS light comes on, you need to get it bacl to the shop before you experience a failure or loss of stopping power. ASAP
This is serious if this is the case. As landrover mentioned, with a ABS light on wouldn't you still have normal brake function. Just no ABS capability.
Not so, on the older vehicles, you can loose your pump/pressure/stopping power, depending on the actual ABS fault. Not wise to tell some he will only loose the ABS function, I have known a number of people who lost their brakes completely. With a new vehicle from 99 and up, yes, you will only loose the SBS, ETC and HDC functions and retain your brakes.
Old 04-04-2008, 01:44 PM
Phototone's Avatar
Default I was wrong about which light is on.
ORIGINAL: CandiMan
Well do I feel embarassed. The actual yellow ABS light goes out just about as soon as I start forward motion in the vehicle. What is staying on is a red light or letters that say SBS. What is that?
Old 04-04-2008, 03:09 PM
Default RE: I was wrong about which light is on.
SEAT BELT, maybe.
Old 04-04-2008, 10:26 PM
CandiMan's Avatar
I assume you meant to say SRS
S-upplementary
R-estraint
S-ystem
i.e air bags
Alan Phillips
11-19-2018 03:27 PM
Anxious Jim
12-11-2013 12:39 PM
pwaltrip
06-12-2012 05:55 AM
JerrodSteph
06-12-2011 06:04 PM
mara9205
10-22-2010 04:44 PM
Quick Reply: ABS lights on after brake line repairs.
