ABS MODULATOR FIX (NO more SVS fault)
Old 04-09-2012 | 08:44 PM
mx468's Avatar
Just finished the option b, changed out shuttle valves, rewired, replaced modulator, bled modulator and bled all brakes, took me 1 hour 45 min. Adios tres amigis. Everything went great and thanks to everyone on this forum. If anyone needs help with this fix I live in Rhode Island. Peace!
  #92
Old 06-01-2012 | 07:12 AM
autoaddict's Avatar
just bought my disco II (03) with 200,000km has a few issues including the three amigos until I followed your advice and performed the simple option B...2hours later, no more amigos! Great advice, I recommend this procedure to anyone with the amigo blues! Thanks a lot!
  #93
Old 06-12-2012 | 10:03 AM
blairrf's Avatar
4wd High
Default Not Amigos Free
2002 DII and Im trying to get the TC working so I can take the thing offroading this weekend.
The instructions were awesome and everything tested out on the ohm meter but Im still getting the amigos.
So i had the bright idea to check the fuses, after the fact...they're all good.
Then I saw this connector that is free floating near the ABS - can anyone tell me what it is?
Does anyone have ideas on what I should be checking to get rid of the amigos because apparently, it wasn't the SVS failing.
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
  #94
Old 06-12-2012 | 10:38 AM
oilspotLR's Avatar
Get the codes read. The auto zone scanner won't read it though. You need the "amigo" reader. Or take it to the dealer and tell them you want the codes read.
  #95
Old 06-12-2012 | 11:00 AM
blairrf's Avatar
4wd High
Any clue what that connector is?
The image didnt show up in my previous post, but the link works.
  #96
Old 06-12-2012 | 11:57 AM
drowssap's Avatar
that is a plug for an ABS sensor, but before you say Hey I found the problem.
it may not be your problem, the original sensors plugged in like that, the new replacements get wired all the way back to the cpu. So it is common to leave the old wire were it is. I had the same problem, found that wire, and was happy as hell that it was going to be an easy fix, wrong.
  #97
Old 06-12-2012 | 02:44 PM
blairrf's Avatar
4wd High
drowssap what was your fix?
I never did any work to the ABS before - are you saying a previous owner could have replaced it with the "new" type connection and just not removed the existing wire?
in any case - what/where would the part in my picture plug into?
  #98
Old 06-13-2012 | 07:34 AM
drowssap's Avatar
that is my guess,
again "guessing" it went to one of the front wheel sensor.
the original sensors had a two piece cable with a plug,
the replacement cable on one piece which goes from the wheel to the ecu.
I have none nothing with mine as it does not effect anything, I tried grounding it, covering it to insulate it neither made difference on my truck.
it still sitting there tucked away under the hood.
if you find out differently please let me know.
  #99
Old 07-14-2012 | 10:21 AM
al3030's Avatar
Thank you very much is a very detail explanation I have been having 3 amigo problems for 2 1/2 years definitely going to try this out keep you posted
  #100
Old 07-18-2012 | 07:38 PM
igrindstaf's Avatar
3rd Gear
I did the option "b" repair and it cleared up my lights. before I went for the compleat repair I cut the yellow/green wire and put a 3k resistor in series with ground to make sure the three friends went away. also I used a dvm to check the yellow/green wire going into the modulator to see if it was showing open and it was. Ivan
Quick Reply: ABS MODULATOR FIX (NO more SVS fault)
