ABS MODULATOR FIX (NO more SVS fault)
Old Nov 6, 2014 | 10:42 AM
  #201
tberg44's Avatar
Originally Posted by scarpinatore
Hi,
as I wrote a few posts above, you can find the pdf files with all images here
Just download the three pdf files linked in the page or download the following (same links):
link 1
link 2
link 3
@scarpinatore thanks. I did see your posts above but there are two problems:
1. The whole page is in Italian.
2. Once I found where the three files were located it said: "Non hai i permessi necessari per visualizzare i file allegati in questo messaggio", which translates to me not having permission to view the files (Thanks Google Translate).
Does anybody have a working link for this or a place that will allow me to download the PDFs? Thanks!
Old Nov 7, 2014 | 07:34 AM
  #202
scarpinatore's Avatar
6th Gear
send me your email (in a private msg if you prefer) and I will send you the three files
Old Nov 8, 2014 | 05:09 PM
  #203
clubagreenie's Avatar
3rd Gear
I used an Internet Page archive site. I didn't capture every pic used in the page in question but it did have all the ones relevant to the work in question. From there it gave me the option of saving the page locally. So now I can just open the sites index page locally and look at the whole site at the day it was last captured.
Here's the archives sit URL for the page:
https://web.archive.org/web/20140207...verclubvi.com/
Old Nov 9, 2014 | 08:01 PM
  #204
tberg44's Avatar
This is the same page that I have been to before. Unfortunately not a single image loads on said page. Thanks though
Old Nov 9, 2014 | 10:40 PM
  #205
3rd Gear
I've got the whole page for that section, pics too (at least most of them). The whole folder is only 3.6 meg. I can email it if you like, hope it's enough to get through.
Old Nov 10, 2014 | 01:03 AM
  #206
tberg44's Avatar
Thanks! I'll shoot you my email in a PM.
Old Jan 23, 2015 | 03:42 PM
  #207
dparham's Avatar
here is what my Code reader said...
-----ABS Amigo Box V1 RSW Solutions LLC Copyright 2010-----
|* The information provided is without warranty of any kind.*|
|* IN NO EVENT SHALL RSW Solutions BE LIABLE FOR ANY LOSS OR*|
|* INJURY OR DAMAGES resulting from or connected to use of *|
|* this Information or Product. YOU HEREBY WAIVE ANY AND ALL*|
|* CLAIMS AGAINST RSW Solutions ARISING OUT OF YOUR USE OF *|
|* THIS INFORMATION OR PRODUCT. *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
021:Engine PWM signal bad
022:ECU Gnd or Reference Gnd bad
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
033:Front Left out valve open circuit
034:Rear Right in valve open circuit
035:Rear Right out valve open circuit
047:Rear Right sensor output low
074:Rear Right in valve short to supply
Front Right Sensor Bad Output
Rear Left Sensor Bad Output
Rear Right Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Old Feb 3, 2015 | 07:36 AM
  #208
lndrover@carolina.rr.com's Avatar
Default abs fix
I tried your link and i get some crazy website. Not your instructions. would really like to read your info. Thank You. Courtney
Old Feb 7, 2015 | 06:24 PM
  #209
psg's Avatar
psg
4wd High
Where are the moderators and why is this still a sticky? I've wasted a bunch of time as have others and not getting anywhere.
Stu
Old Feb 7, 2015 | 06:36 PM
  #210
dusty1's Avatar
Stu
I thought you guys uploaded some saved info a few pages ago. Something like pics are lost but the info is still there, correct🗿
