ABS relay draining battery
Old Oct 20, 2012 | 06:31 AM
discodaft's Avatar
Default ABS relay draining battery
Hi folks - new member here so be patient!! I've bought a 2001 Discovery Td5 but had a parasitic draw on my battery which was leaving it flat after a couple of days . With ignition off there is a chattering/ticking noise from passenger side behind bulkhead somewhere. No warning lights on though. With a bit of help worked out it's to do with abs by pulling fuses until amps draw dropped to normal. If I leave the 30amp fuse out the chattering noise stops and I've just come back from a week away and battery still has plenty of power to start the disco . Looking into it a bit it would seem to be some sort of relay (or solenoid) that is causing the problem. The sound we are hearing would appear to be power switching on and off and draining power. Can someone out there tell me how to locate the faulty relay/solenoid and how to replace it?? Thanks in advance....
Old Oct 20, 2012 | 08:08 AM
Do you also have self leveling suspension? Which can try to keep leveling after key turned off. Also, which fuse number is it from which panel (inside truck or under hood)? The RAVE has very good electrical troubleshooting manual and circuits diagrams. The 30 amp fuse goes to the SLABS ECU, the 30 amp fuse link (bolts in) goes to the ABS pump. Once you look at things on the circuit digram (like an old road map, a colored line runs from "X" to "Y"), you note a small connector number beside the device. Go to the electrical guide, connectors, and there is a picture and location of that part. In living color on a Disco that is soooooo cleeen they must keep in in a jar.
Old Oct 20, 2012 | 08:38 AM
There was a TSB (technical service bulletin) on this problem, the ABS is supposed to stop cycling after 10min of turn the truck off.
The fault was the ABS would keep "working" and drain the battery.
Take the truck to your dealer and have them look up the VIN# to see if the TSB has been performed on your truck.
Old Oct 20, 2012 | 08:47 AM
There would only have been work for that problem, done by the dealer at customer expense, not under warranty and as such the dealer can't help determine if the work was done.
Old Oct 20, 2012 | 11:28 AM
discodaft's Avatar
Thanks for replies. I'll check at the beginning of the week if the TSB has been carried out on my car.
The disco did have self levelling suspension but this has been removed by previous owner. The fuse I removed was the 30 amp one from the fusebox in the engine compartment ... the one in the middle row which is marked as ABS on the fusebox cover.
Hope this helps
Old Feb 27, 2026 | 02:53 PM
Sandman614's Avatar
Old thread, but would love to know what that TSB number and details are. I'm ready to make my battery stop draining.
Old Feb 27, 2026 | 07:17 PM
mln01's Avatar
I too would like to know the TSB number. I looked through my list of DII TSBs and didn't find it.
I drive Redrover only occasionally these days, and over time the battery would discharge. Redrover is garage-kept, so I bought an inexpensive battery maintainer / trickle charger to keep the battery topped up. If your DII is parked outside, you can buy a solar-powered battery maintainer. The solar array would sit on the dashboard. Years ago I rewired the cig lighter to be always on, so I could plug a solar charger into the lighted socket.
Old Mar 1, 2026 | 12:55 PM
Sandman614's Avatar
Still want to know what LRs fix was, but in the meantime I'm going to dig. I plan to open up my spare SLABS unit and map out what internal relay is being controlled that lets the unit timeout, which is obviously failing to turn the unit off. This post from another Rover site(which charges for basic usage, posting/viewing pics...and as such I won't be posting my findings there) has a writeup that Adds an ignition switched relay to the main power feed, fuse 11 to pin 1, of the SLABS unit. I would like to fix the actual problem not slap a bandaid on it.
https://www.aulro.com/afvb/discovery...ery-drain.html
boom_r6
May 27, 2010 08:03 AM
asikuy
Jan 5, 2010 09:13 PM
richief556
Jul 23, 2009 08:29 AM
94LWBrangie
Sep 27, 2008 11:23 AM
barcroft
Sep 27, 2008 09:44 AM
