ABS repair kit
Old Feb 25, 2014 | 05:33 PM
acg's Avatar
acg
Originally Posted by sorusty
I have the 3 amigo lights just like everyone else. I found on Amazon a ABS module repair kit. I was wondering if anyone has used this and know if this will fix the problem.
here is the link for the part:
Proper Spec SWO500030 ABS Modulator Switch Repair Kit : Amazon.com : Automotive
thank you!
I did a quick check.... turns out the Proper Spec vendor is actually Lucky8 LLC.... one of our more popular vendors in this forum
Amazon.com At a Glance: Proper Spec
Old Feb 25, 2014 | 08:25 PM
xxdoylexx's Avatar
Code reader if you have a laptop you should buy the autocom cdp + you can buy them from china for under 100 dollars and will allow to check most system including abs on your doscovery. it will also allow you to clear those codes
Old Feb 26, 2014 | 12:26 AM
Rover_Hokie's Avatar
You want to use the full kit with the o-rings/seals or you you may end up back in there again to replace the o-rings/seals. They dry out and leak. The Falconworks kit is complete, use it. Falconworks - 3 Amigo ABS shuttle valve repair kit with new seals
With the instructions included with the repair kit and the pics and instructions from the Virgin Islands LR Club http://www.landroverclubvi.com/abs-mod.html it is a pretty straightforward repair once you do your reading and get your game plan together.
aarongregor
Dec 1, 2015 08:43 AM
aarongregor
Jan 16, 2012 07:02 PM
Willie 00D2
Sep 29, 2008 09:59 PM
majrmike
Oct 9, 2007 03:13 PM
