ABS Sensor loose in hub assembly.
Old Jul 6, 2023 | 01:26 PM
Black.Rhino's Avatar
Default ABS Sensor loose in hub assembly.
Brand new hub assembly and the abs sensor is loose not seated properly in the hub. Can the sensor be simply pushed back in? It's been a while since I've replaced a wheel hub assembly.
Old Jul 6, 2023 | 03:23 PM
Extinct's Avatar
Yes, there should be an o-ring in there to keep it snug.
Old Jul 6, 2023 | 04:29 PM
Does it require removing the hub assembly?
Old Jul 6, 2023 | 07:06 PM
Extinct's Avatar
Yes and no, you can remove the sensor from the hub mounting but the connector will not fit through the hole between the hub and knuckle on the front hubs (another ****ty design by LR, I want to kick the engineers ***).
mln01
Oct 19, 2021 01:04 AM
Black.Rhino
Apr 12, 2021 05:19 PM
ukwildcats
Jul 13, 2013 07:30 PM
kjgale
May 16, 2012 10:04 PM
Disco_Fever
Mar 3, 2011 11:38 AM
