ABS Sensor removal 99 Disco II
Old Feb 20, 2010 | 03:41 PM
tbesselman's Avatar
Default ABS Sensor removal 99 Disco II
I have 99 Disco 2 that I get the following ABS code from my Amigo scan: and I happen to have a spare Front ABS Sensor - But how do you get to the sensor to try to replace it. andy ideas (do I need to take the wheel off and access it that way......any ideas or help
|* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *|
|* www.RSWsolutions.com *|
|* Version V1.1 *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
Front Left Sensor Bad Output
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
<-END Faults
Old Feb 20, 2010 | 04:05 PM
lipadj46's Avatar
Take off your rotors and use a small allen wrench to remove the sensor. Be warned it may be your hub though.
Old Feb 20, 2010 | 08:16 PM
tbesselman's Avatar
How can you tell whether it is the hub that needs replaced or the sensor? I hate to drop $400 on a hub and sensor, if I can get away with just the sensor......or should I just bite it and replace the hub (I have 104K on it with the original hubs) Disco Mike any ideas?
KlamathMatt
Apr 17, 2020 05:27 AM
LADEROUTE
Mar 12, 2014 08:58 PM
Rover Newbie
Oct 9, 2013 04:50 PM
twaszak
Jun 4, 2011 07:49 AM
