abs/tc/hill decent lights on
Old Sep 5, 2007 | 04:23 PM
02DiscSD's Avatar
Default abs/tc/hill decent lights on
My abs/tc/hill decent lights came on the other day. I'm sure it was just luck that my front pads were ready for changing, since I changed them and the lights are still on. I also got a code 1590 01 tried to reset them but with no luck. I read on here you need a laptop code reader to get deep into the computer for reseting. I know with my old MB I could reset the codes by removing the battery cables and touching them together(always worked). Is there a simlar way to reset the abs/tc/HD lights? Any ideas what would cause this? Thanks in advance this is my first post Steve
Old Sep 7, 2007 | 07:59 AM
mcneal's Avatar
Default RE: abs/tc/hill decent lights on
Your problem is commenly reffered to as the three amigos. There are tons of posts about it. I would search the forum and read old posts. Someone posted an excellent shuttle valve replacement walkthrough recently, this might also be of intrest to you. Good luck!
Old Sep 7, 2007 | 08:52 AM
So you don't waste alot of time, you can't clear the trio of lights your self. It will take a T4 Rover scanner or something equivalant to a Auto Logic scanner. Don't be surprised at what it will cost. Dealer charge the most, usually between $100 and $150 and they will not reset the lights till you fix the problem. Small shops usually charge less and in some cases if you ask them to clear the codes they will.
Old Sep 8, 2007 | 07:03 PM
02DiscSD's Avatar
Default Thank you guys for your help (eom)
Old Sep 11, 2007 | 12:17 PM
Dahne23's Avatar
Default RE: Thank you guys for your help (eom)
curious, if the codes get cleared w/o fixing the problem, will they eventually come back on??
Old Sep 11, 2007 | 12:23 PM
If there is in fact a problem, the lights will come right back on, if it was just a glitch they will stay off.
Old Sep 11, 2007 | 12:24 PM
okdiscoguy's Avatar
depends on what the codes are and what set them off. get the codes and it will tell you where to look if they come back on.
gsgtsg
Dec 3, 2008 08:41 PM
kev c
Freelander
Aug 4, 2008 06:06 PM
dsmtrain
Jul 12, 2008 07:15 AM
shagybruce
Sep 7, 2007 05:07 PM
dgd
May 16, 2005 03:58 PM
