ABS and TCS lights come on and off......
Wierd.... the lights come on about 30 seconds after I start the car and when I put it in Drive. I drive with it on till I get to my destination..... the next time I start the car the lights go away.
Why would this happen?
The front brakes are about 85% worn. The rears are 45% worn.
Any advice?
Any advice?
on
RE: ABS and TCS lights come on and off......
Do your brakes squeak, did you use lots of sound deadening spray on the back of the brake pads and did you do a full, 3 pint brake bleed when doing your brakes?
As already mentioned, you will need to have someone read your ABS faults to find out for sure. You might go and do a hard stop at 30 MPH plus and see if you can still feel the ABS shutter thru your brake pedal.
cipher982
12-13-2011 07:50 PM
