Power Steering / Check Engine
Old Oct 4, 2008 | 01:36 PM
99LRDisc's Avatar
Default Power Steering / Check Engine
Was low, lots of noise, griding when turning, and even while idle. Added ATF Dexron as told by Spike a bit ago. Next day, check engine light on. Possibly related? Should i get it in right away?
Old Oct 4, 2008 | 08:30 PM
Default RE: Power Steering / Check Engine
They are not related. you could run with the power steering pump compleatly dry and the check engine light wouldnt come on. The pump would be fried, but the light woudnt come on.
Once you topped up the power steering did the noise go away?
Old Oct 5, 2008 | 09:03 AM
Is your noise back? Have you gone and had your codes checked at a local auto parts store yet, if so what were the codes?
FlyingZebra34
Feb 22, 2014 05:39 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
