ABS WHEEL SENSER
Old 01-11-2009 | 07:12 PM
Default RE: ABS WHEEL SENSER
ORIGINAL: unimoged
Great subject on a Disco. Maybe Disco Mike can shed some light on this situation that I am dealing with, on the 2000 SD (78 K Miles).
The hill decent, ABS and traction lights came on at the same time after going over a very hard step.
Took it to the dealer to get the ABS modulator valve covers recall done and they informed me that I have a code for left front harness and a code for rough terrain, if I recall right, in the slabs ECU.
Checked harness for continuity / short / open, from ECU pins to sensor connection on the inner fender well. Checks are OK.
Checked resistance on the ABS sensor left and right front. The reading is 1015 ohms for both.
Checked the hub, it is good.
Any ideas.
Send me your tele number and lets talk.
Mike
Old 01-12-2009 | 02:56 PM
ERICM63's Avatar
8th Gear
IS IT SAFE TO DRIVE MY ROVER IF THE HUB IS CLICKING?
AND THANKS YOU RIGHT A NEW HUB IS MAYBE THE BETTER WAY TO GO FOUND SOMEONE THAT WILL PUT IT IN FOR 175.00
Old 01-13-2009 | 01:35 PM
ERICM63's Avatar
8th Gear
CAN SOMEONE TELL ME HOW SAFE IS IT TO DRIVE WHEN I HAVE THAT CLICKING FROM THE RIGHT HUB
cornbreadj
02-27-2014 12:01 PM
Landlover12
04-02-2011 01:27 PM
redw&blue
10-15-2010 11:05 AM
asat
11-03-2008 10:59 PM
BENROVERN
11-05-2007 10:19 AM
Quick Reply: ABS WHEEL SENSER
