ABS Wheel Sensor Voltage
Old May 5, 2023 | 04:27 PM
PilotHobs's Avatar
Default ABS Wheel Sensor Voltage
Man O Man. I'm abut to pull my hair out. I did option B a while back and everything was great. Then the ABS sensor wire caught on the axle where it connects to the hub and broke. I said well ****. Ordered a new one and put it on. The problem is The voltage off the wire is not increasing with wheel speed. All the others work fine. So I pulled it off AGAIN and looked down in there to see if any of the teeth were damaged. Nada. Just fine.
Some fresh ideas would help.
TIA
Hobs
Old May 5, 2023 | 06:53 PM
Extinct's Avatar
The wheel sensor is not an analog device, it is more digital. Its a magnetic pickup on a the reluctor. Output is a square wave and the frequency increases with speed. you need a special scanner to read it. Do you have a code reader that is giving you a code for the wheel sensor?
Old May 5, 2023 | 07:02 PM
PilotHobs's Avatar
Yes. I actually miss-spoke in my original post. I was using a ILand and reading the real time output of the wheel speed. Each wheel reads normal but the right front. It stays at the same value no matter the vehicle.
It stays at 1.74 no matter the speed.
Ty
Hobs
speed.
Old May 6, 2023 | 03:43 AM
JUKE179r's Avatar
If you ohm out the cable it should be 950-1100 ohms across the 2 wires.
Brandon318
Apr 30, 2023 07:01 PM
John Carlson
Sep 8, 2021 07:06 PM
collector87
Sep 3, 2020 12:27 PM
toofaroffroad
Jun 9, 2016 01:24 AM
sayeedA
Dec 7, 2011 10:19 AM
