abs woes
Old May 20, 2013 | 02:30 PM
FlyingZebra34's Avatar
Default abs woes
So I'm still in the desert tinkering on my rover. Snapped a body mount and lost a few fixable things but the biggest downer is the 3 amigos. The weather is about 110 degrees and the TC and HDC was working great. I replaced the seals and switches a few months back.
I think the system over heated...
Firtst the abs/tc lights came on n it was still functioning but they turned off a bit later. After awhile though they just came on and stayed on.
Old May 20, 2013 | 02:36 PM
dgi 07's Avatar
Couple questions for you.1. Did you hardwire the harness as was indicated in the write-up for the ABS fix?2. How is the name of sweet baby Jesus, did you snap a body mount?
Old May 21, 2013 | 10:19 PM
Sorry I thought I replied to this but I guess it didnt go through.
Well I did not modify the harness, I had some issue with stuck switchs and hoped replacing them according to stock would solve the issue for longer than 2 months. I guess not.
I'll be making a trip to the dealership to get my buddy to diagnose the codes and clear them. I'll let you know asap.
And the first two on the drivers side cracked. I do a lot of woops out in the desert and the vehicle I guess just cant handle them. Nothing some extra metal and a welder can't fix.
simonb1977
Jun 29, 2011 01:23 AM
navysar
Apr 30, 2007 07:57 PM
werldcup
Mar 10, 2007 06:54 PM
chrisusvi
Feb 27, 2006 02:36 AM
nomadix
Jun 24, 2005 03:19 PM
