ac blower motor
Old Jul 30, 2012 | 08:22 AM
30more's Avatar
Default ac blower motor
On my way to work this morning I turned my ac off, went to turn it back on my ac blower motor did not come back. I hear clicking still so I might have a loose connection what is the voltage supposed to be at the blower motor? Anything else you guy can think of?
Thanks
Joe
Old Jul 30, 2012 | 01:12 PM
Could be relay, switch, Ac control, fuse(s), ground lead, and power transistor. On high the voltage would be 12. There are circuit diagrams and color wiring diagrams in the RAVE (shop manual package).
Old Jul 30, 2012 | 06:15 PM
wilson96rr's Avatar
Could also be, and many times is, the fuse box.
Old Jul 30, 2012 | 09:27 PM
30more's Avatar
fuses good, relay good, power at the blower 13.63... so bad motor?
Old Jul 30, 2012 | 10:35 PM
jafir's Avatar
Does the fan work on high? What if you hit the motor with your hand or foot?
Old Jul 31, 2012 | 05:32 AM
30more's Avatar
Fan motor won't come on at all at any speed
Old Jul 31, 2012 | 06:12 AM
drowssap's Avatar
if you have power & ground to the motor and its not moving, thats a pretty good sign you need a motor.
Old Jul 31, 2012 | 06:27 PM
Pricey too, a dismantler may be an affordable choice.
Old Jul 31, 2012 | 08:02 PM
igrindstaf's Avatar
3rd Gear
I had the same thing happen to me on my 2001 disco for me it turned out to be the connector right at the fan motor a couple of butt connectors took care of the problem Ivan
Old Aug 1, 2012 | 09:09 AM
Paul Grant's Avatar
If it turns out you need the blower motor let me know. I have about a dozen used, tested units in stock and they're cheap.
