Ac clutch?
Old Mar 18, 2014 | 03:02 PM
cmfpb's Avatar
Default Ac clutch?
Sooo I recently got a 96 disco & there is this horrible knocking noise coming from my ac clutch...i think. Someone told me thats what it was & it just needs a washer behind it cause it was recently replaced. How do I go about fixing it? The noise is driving me crazy. Can I do anything to make it not as loud till its fixed?
Old Mar 18, 2014 | 03:07 PM
Dane!'s Avatar
If you hub was replaced and the shim fell out and was not replaced then you need a shim. I got mine from ACE hardware, as I rebuilt my AC hub on my D2 and lost the shim. Just use any washer that will fit all the way into the hub, apply a tiny bit of grease to one side of it so when you install it the grease will act as a temporary glue, and Loctite the bolt in.
Old Mar 18, 2014 | 03:34 PM
jamestfl's Avatar
or just turn off the a/c- problem solved!
buttocks
Dec 31, 2014 12:53 AM
parks
Feb 23, 2005 04:11 AM
parks
Jan 31, 2005 12:21 PM
Si
Jan 2, 2005 11:36 AM
lugo35
Engine & Internal
Dec 13, 2004 05:51 PM
