AC compressor?
Old Nov 18, 2013 | 10:07 PM
abran's Avatar
Default AC compressor?
03 D2- It looks like my friends daughters AC compressor is not engaging. The compressor was not running and a cheap AC gauge said the pressure was "warning level" high.
Any tips to get the compressor clutch to engage? I can't add any gas because the cheesy refill I bought at the auto parts store will only get sucked in if the compressor is running.
Lastly, if the compressor is bad, does a D1 compressor fit on a D2?
Thanks in advance.
Old Nov 19, 2013 | 05:18 PM
abran's Avatar
No one has any advice?
Old Nov 20, 2013 | 08:29 AM
drowssap's Avatar
have you checker ECON on the heater control that kills power to the compressor.
if the compressor is not kicking it, your gauge pressures are NA.
Old Nov 21, 2013 | 12:28 AM
abran's Avatar
Thanks for the response drowssap, turns out the fuse/relay in the engine bay was removed by the PO.
AC blows cold now!!!
Old Nov 21, 2013 | 06:23 AM
pkppunk's Avatar
I would make sure the condenser fan is workin as it should if its frozen it might be the reason the PO pulled the relay to prevent the truck from over heating
Old Nov 21, 2013 | 11:01 AM
abran's Avatar
Thanks pkppunk, it's a spinnin'.
PO was a kid who on one hand paid a lot of money to have the car maintenanced/repaired, but on the other did some **** poor repairs/upgrades.
Old Nov 21, 2013 | 11:05 AM
Paul Grant's Avatar
DI and DII compressors are, more or less, the same. There was a change in the style of the connector some time during the DII's run but I can't remember when.
Old Nov 22, 2013 | 08:10 AM
abran's Avatar
Thanks Paul. I'm going to look into it further for future use.
Old Nov 22, 2013 | 10:00 AM
04duxlr's Avatar
Strange. Maybe he used it to replace another relay that had failed?
Old Nov 22, 2013 | 08:24 PM
abran's Avatar
Seems he took it out for a reason. Car is overheating now...
KWLR3
Jun 24, 2006 06:10 PM
2k2wranglerx
Mar 15, 2006 05:05 PM
still11
Nov 21, 2005 07:51 PM
DiscoGravy
Oct 1, 2005 08:22 PM
camcor
Aug 10, 2005 11:07 AM
