Ac compressor seized or clutch failure?
Old Feb 11, 2019 | 08:44 AM
Ben Matheson's Avatar
Default Ac compressor seized or clutch failure?
Sitting at a light and a squeal started under the hood. Turned off the AC and it went away. Looked at the belt and appears ok so nothing completely locked up.
Trying to determine if it's clutch or compressor because if it was compressor I should probably change the condenser due to metal fragments.
Can anyone advice how to tell what happened?
Old Feb 11, 2019 | 10:16 AM
Lisa Bunch's Avatar
The A/C clutch on our F350 has shims, but check out this You Tube, it might help:
Old Feb 11, 2019 | 02:08 PM
Thanks but imI looking to tell if the compressor has grenaded
Old Feb 12, 2019 | 12:33 AM
razorkill12's Avatar
Look for red around pulley like it overheated.....also take belt off and rotate ac compressor pulley. While belt off check other pulleys
Wilson7287
Feb 28, 2017 09:29 AM
ge234
Sep 24, 2015 08:30 AM
dansgt
Dec 7, 2010 08:27 PM
robbster91
Jan 28, 2010 11:06 AM
tads
Aug 27, 2008 04:15 PM
