AC Compressor Swap
Old Oct 22, 2022 | 12:27 PM
zski128's Avatar
Default AC Compressor Swap
My AC compressor has 214k miles on it and it’s leaking refrigerant and the clutch is gone. Getting a used one shipped to me next week. I see there are two o rings needed and found the OE ones but they are $15 each and they are also out of stock. Any recommendations on a good set to replace?
Old Oct 22, 2022 | 03:08 PM
keninnc's Avatar
Autozone or similar store. Pack of multiple sizes goes for about $5. My opinion as long as they are the green version and the size is right it should work fine.
Old Oct 22, 2022 | 08:31 PM
XRAD's Avatar
if your truck experienced salt, careful with the 4 mounting bolts....
Old Oct 23, 2022 | 07:07 PM
zski128's Avatar
Life long New England truck so yes…much salt. Thanks for the heads up.
Old Oct 26, 2022 | 02:57 PM
WaltNYC's Avatar
https://www.ebay.com/itm/17542177633...Bk9SR4Sq792CYQ
Old Oct 27, 2022 | 11:31 AM
zski128's Avatar
@WaltNYC thanks for the link to the rebuild kit. I ended up getting a used compressor for $65 and installed that along with a rebuilt alternator while I had everything apart. I got a o ring kit from Amazon. The two sizes needed are 9/16 and 7/16” o rings. The whole swap took about 2 hours with most of the time spend cleaning up all the oil and dye off the AC bracket. No issues with corrosion on any of the bolts however the AC line bolts had a ton of loctite on them.
oaty
Jun 16, 2021 07:34 AM
Kellyfam7
Jun 7, 2020 10:45 PM
robbster91
Jan 28, 2010 11:06 AM
wizardmagu
Dec 17, 2009 07:17 PM
tads
Aug 27, 2008 04:15 PM
