AC Drain Points
Old Jul 6, 2011 | 09:37 PM
DiscoRover007's Avatar
Default AC Drain Points
So I found today that I had some water soaked in the edge of my passenger side floor(near the plastic trim), front and rear doors. I found water dripping off the corner of the side body trim, rear passenger side door area, right in front of the tire, near the mud flaps. I searched the forum and I've read that this means that the drain nipples are clogged.
I've only been aware of one drain nipple on this truck and it's the only one I've seen water come out of and it always leaks water after a drive. I'm speaking of the one next to the transmission and drive shaft on the passenger side. Where exactly are the other ones?
Thanks as always
Old Jul 6, 2011 | 09:45 PM
DarylJ's Avatar
You should see the other one in about the same place on the other side of the transmission.
Old Jul 6, 2011 | 10:14 PM
Also my fuel door keeps opening while driving. Is there something I can do to keep it secure?
It's happened before and I used bubble gum to keep it to stick(gross I know) but it worked. What's causing it come loose?
Old Jul 6, 2011 | 10:41 PM
mishon's Avatar
It sounds like the door clip has worn out, its made of plastic and over time loses tension. I fixed mine by placing a piece of 16 ga electrical wire cut to 3/4" between the space on the clip to increase the surface area that engages on the door latch. Hope this helps, I know a pic would be better but can't post one right now so if you do need to see what I described above I can have one for you tomorrow.
Old Jul 6, 2011 | 10:47 PM
Yea man I would really appreciate that.
Old Jul 6, 2011 | 11:26 PM
mishon's Avatar
Let me know if this works for you as the 03 door latch should be the same design as on the 02.
Old Jul 7, 2011 | 06:50 AM
DarylJ's Avatar
The replacement latch is $4.95.
Old Jul 7, 2011 | 08:02 AM
mishon's Avatar
Yup...5 bucks, but expect the replacement to start doing the same at some point...some sooner than later as the solenoid pin (operated by the switch) is sometimes worn as well.
Old Jul 10, 2011 | 06:14 AM
Fairview's Avatar
Yes, that is where mine is on my '03. It drips right on to the transmission selector switch! Now that was some good planning!
Old Jul 11, 2011 | 06:43 AM
LundRover's Avatar
I can't seem to find my drain points, anyone have a photo?
