AC/Heater control unit question
If you dont have a owners manual go to www.atlanticbritish.com, tech tips, left side of the home page.
Print that page and stick it in your glove box.
I ran into an interesting one the othe day while driving the rover (2004 D2).... had the passenger temp turned up to 68 F and the Driver side temp at 64F. The passengers was pretty cold, and the Drivers was hot. (read - not 64). I screwed around with moving them up and down, and turns out the driver side is always about 20 degrees warmer than the passenger, regardless of what the temp says on the display. I have flushed the coolant system, and DID bleed it with the bleed screw (And rechecked a couple times to verify there was no air in the system).
Never had any issues with overheating, etc., temp rock solid right in the middle as always... and the car was well warmed up...
Any ideas on this?
Any ideas on this?
Arsene
04-06-2009 08:49 PM
SantaCruzRoverGirl
01-20-2009 02:49 PM
