AC/Heater control unit question
Old Feb 25, 2009 | 08:13 AM
MBD506's Avatar
Default AC/Heater control unit question
Hi, new guy here. I have a 2000 Land rover discovery2 with 95000 miles.
How can I change the the reading of the temperature on the ac control unit display from C to F.
Thanks in advance
Old Feb 25, 2009 | 09:28 AM
I realize this is your first post, have you tried a search or checked your owners manual prior to asking?
Old Feb 25, 2009 | 07:29 PM
If you dont have a owners manual go to www.atlanticbritish.com, tech tips, left side of the home page.
Print that page and stick it in your glove box.
Old Feb 27, 2009 | 10:58 AM
04BluDisco's Avatar
I ran into an interesting one the othe day while driving the rover (2004 D2).... had the passenger temp turned up to 68 F and the Driver side temp at 64F. The passengers was pretty cold, and the Drivers was hot. (read - not 64). I screwed around with moving them up and down, and turns out the driver side is always about 20 degrees warmer than the passenger, regardless of what the temp says on the display. I have flushed the coolant system, and DID bleed it with the bleed screw (And rechecked a couple times to verify there was no air in the system).
Never had any issues with overheating, etc., temp rock solid right in the middle as always... and the car was well warmed up...
Any ideas on this?
Old Feb 27, 2009 | 04:28 PM
Your passenger blend door is probally stuck and wont let enough air in.
Is the fan as strong on that side as the drivers side?
Old Feb 28, 2009 | 08:14 PM
04BluDisco's Avatar
seems the fan is about the same... Any tricks for unsticking the blend door? Fist pound on the dash? new flux capacitor?
Old Nov 13, 2009 | 10:39 AM
04BluDisco's Avatar
Anyone have any fixes for a sticking Blend door? Definitely more noticeable since it's now fall....
Old Nov 13, 2009 | 07:41 PM
Beat the dash with your fist.
Old Nov 14, 2009 | 05:24 PM
RoverRowell's Avatar
5th Gear
Angry 96 disco dome lights
My 96 disco has no interior lights, fuses are good, they don't turn on when I open the door. Back or front. Any easy fix on this one...THANKS
(lights are new)
Old Dec 7, 2009 | 03:02 PM
04BluDisco's Avatar
any other suggestions for unsticking the passenger blend door, pounding with a fist aside? Tried that, no luck.... alternatively, anyone know where its located? and I can start to look at it that way?
Thanks
DancerDeb
Freelander
Jan 16, 2014 02:39 AM
Arsene
Apr 6, 2009 08:49 PM
SantaCruzRoverGirl
Jan 20, 2009 02:49 PM
Phototone
Apr 8, 2008 03:46 PM
98roverguy
Oct 13, 2006 04:48 PM
