AC/Heater Vent Box
Old Nov 7, 2016 | 03:43 PM
cbwhitley's Avatar
Default AC/Heater Vent Box
Hello All
Has anyone changed an AC Vent box?. My Truck is blowing cold air on the drivers side and heat on the passenger. It is located just to the right of the door you can open under the steering wheel that allows access under the dash. The control module for the drivers side is stripped and will no longer step up or down the temp. I can manually move a lever and it will adjust the temp but it's getting old crawling under the dash to adjust it.
Does the dash have to come out or can it be removed another way?
Old Nov 8, 2016 | 09:04 AM
russburcham's Avatar
Ive heard the dash needs to come out to replace. Also the box gets very brittle and causes low air to the actual vents as the air is escaping into the dash. I was quoted about $1,000 to replace from my indie
ls1morethanyou
Jan 12, 2017 10:21 AM
Rigndip
Feb 15, 2014 05:21 PM
KlamathMatt
Oct 29, 2013 12:15 PM
JavaDiscoII
May 16, 2010 03:34 PM
alpinab7
Nov 29, 2006 11:27 AM
