AC only blows cold on drivers side
Old Jun 11, 2007 | 05:10 PM
Brad S1's Avatar
Default AC only blows cold on drivers side
Does not blow cold on the passenger side, what could be causing this?
Old Jun 11, 2007 | 07:06 PM
Default RE: AC only blows cold on drivers side
Lets start with the basics, year, model and mileage???
Have you done the self test mentioned in the owners manual?
Mike
Old Jun 11, 2007 | 07:44 PM
Brad S1's Avatar
No I don't know about the self test... it's a 98 d1
Old Jun 23, 2007 | 01:04 PM
loic's Avatar
ORIGINAL: Disco Mike
Mike
hey Mike, my a/c (2001 disco II) is also warmer on the passenger side i checked the user manual but couldn't find anything. is the 01 model different ?
Old Jun 23, 2007 | 02:22 PM
Send me an e-mail address and I'll send you a PDF file on the test, this is for a D2 but I think the D1 has a similiar test.
Mike
Old Jun 24, 2007 | 12:47 PM
Smorgan2004's Avatar
Hey Mike... I got the same problem with my A/C do you mind sending me the pdf as well. Thanks Scott...98 disco
Old Jun 24, 2007 | 01:22 PM
I believe the file is onlt for D2's sorry.
Mike
Old Jun 25, 2007 | 09:56 AM
Hey did you get this one figured out. I check behind the glove box tomake sure the temp dial is working and it appears to be working properly. One of my friends mention that it might be the blend doors but I don't know where those are. Any suggestions?? Scott 98 d1 A/C was just charged. I checked the pressures and the looks good. 50 low side and 225 high side. I'm new to A/C and was told that this means the system is full. pressures checked with the a/c on full blast front and rear.
Old Jul 12, 2007 | 12:54 AM
Just want to get the post in front. I still have the same problem
Old Jul 5, 2008 | 04:54 PM
loic's Avatar
did you ever figure it out ?
2001_Disco
Dec 10, 2014 01:36 PM
dezlpower
Oct 11, 2011 09:35 PM
garryinfl
Apr 27, 2011 03:41 PM
VikingDiesel
May 22, 2009 07:34 PM
