AC Recharge Advice for my 01 D2 SE7
Old 05-30-2011 | 02:26 PM
Kanata.disco's Avatar
3rd Gear
Default AC Recharge Advice for my 01 D2 SE7
01 Disco II
SE7
V8 4.0
166 K (103,147 Miles)
OK so my A/C needs to be recharged, I have done some research and would like to make sure this will work before I move forward
here is the kit I want to buy
RED TEK A/C Refrigerant Recharge Kit | Canadian Tire
will I be able to re-charge my AC system with this?
I have found in the past for some reason the 01 DII's have allot of proprietary parts.
Thanks in advance
Old 05-30-2011 | 03:28 PM
jafir's Avatar
You don't want a drop in replacement for R12. You want actual R134a. It's cheap and readily available. You may want some with dye in it, just because the SE7 probably has rear air, which means you got a lot more fittings and places it could leak out.
Old 05-30-2011 | 03:38 PM
You want that "kit" but you want plain old R-134A as already stated.
But you need the hose and gauge.
DIY a/c recharge kits are available at any auto parts store as well as some big box stores.
Old 05-30-2011 | 04:06 PM
DarylJ's Avatar
As mentioned, you need R134a, not R12. ANd spend a few dollars more and get a real gauge set.
Here's my tutorial on charging AC which I made so I didn't have to repeat it 15 times a year this time of year.
Old 05-31-2011 | 06:59 AM
3rd Gear
Thanks for the responses and the step by step, question I have though. This Kit says its a replacement (equivalent) for R134a and R12
Whats the difference? not sure if I can get R134a in Canada, which is why I assume you can only buy these types of kits.
Thanks
Old 05-31-2011 | 07:54 AM
They do things a little differently in Canada and I would suspect that if the can says 134 or R12, then it will be fine, just confirm it with them when you buy it.
Old 05-31-2011 | 08:09 AM
drowssap's Avatar
I have to admit I have never seen "A direct replacement and retrofit option for R134a and R12 refrigerants for automotive air conditioning systems" before.
I think in the fine print you will find that you can use it to replace either one or the other, but i have never heard of anything that can be mixed with them. in other words in order to use it you may have to drain your system completely, pull a vaccum and refill the system with this product. 134a should be available in canada, I thought you people had even better EPA laws than we did down here. Your truck originally came with 134a.
Old 05-31-2011 | 08:31 AM
DarylJ's Avatar
The difference is that it is a non azeotrope blend that you won't ever be able to recharge properly because the gases escape at different rates.
Looks like you need a certification to get R134a in Canada, not unlike getting R-12 in the states. Not sure what to tell you there, other than to get real R-134, whether that means getting cert (it's a $25 online process here) or going to a garage.
If you use the "replacement" stuff not only won't it cool as well, but if you need to top off again you'll either lose even MORE cooling capacity or have to vac the entire system to replace it with real R-134a or a full load of the substitute.
Old 05-31-2011 | 08:42 AM
3rd Gear
AH, Good to know, thanks for that.
Appreciate everyone's time
Old 05-31-2011 | 09:15 AM
jafir's Avatar
How far are you from the boarder? If not too far, just drive down and go to wal-mart
duckhunteryolo
06-23-2018 02:02 PM
Brianjw82
08-26-2012 11:36 PM
demonlarry
08-07-2011 06:40 PM
robbster91
06-03-2010 10:58 PM
jrkstore43
06-16-2009 09:34 PM
