Stripped Lug Nut Thread
Old May 28, 2011 | 06:55 PM
acsink's Avatar
Default Stripped Lug Nut Thread
Don't know how the hell this happened. But it just spins and spins without going anywhere. Not sure if its the nut or the stud. Any suggestions on getting it off?
Old May 28, 2011 | 08:12 PM
Banzai Jimmy's Avatar
Get the other four off first. If it's the nut, then you should be able to apply pressure to the wheel and get the nut to slide off. If it's the stud, try using a wrench on the nut and apply outward pressure as you turn the lug nut off. Maybe you can get the stud to bite this way. Good luck.
Old May 28, 2011 | 08:30 PM
NiteTrain's Avatar
find a socket that is close and beat it on there with a hammer..might ruin your socket but you have to get the lug off no matter what
Old May 30, 2011 | 09:37 AM
My interpretation of the problem is that either:
- the threads of the lug nut have stripped
- the threads of the wheel stud have stripped,
- the "teeth" of the stud where it is pressed in have stripped, and/or
- the hole where the stud is pressed into has stripped.
I didn't get the impression that the outside of the lug nut was stripped.
Old May 31, 2011 | 08:38 AM
dcarr1971's Avatar
One other possibility that I've recently encountered:
- The S*@#!! cap on the lug has stripped and is turning without actually turning the lug itself.
Resolution is the same as above, beat a slightly smaller socket on to the lug and proceed with removal...
carlos84
Apr 12, 2017 09:43 AM
sayeedA
Feb 25, 2012 12:35 AM
liPPy
Sep 7, 2011 02:55 PM
Rover Chris
Feb 13, 2011 12:03 PM
97DISCOIDAHO
Aug 30, 2006 02:57 AM
