Acceptable Temperature Drop Across Radiator...
Old Jan 21, 2018 | 01:47 PM
The_OGCJR's Avatar
Default Acceptable Temperature Drop Across Radiator...
I've searched and I could not find a definitive answer here. Seems like average is -30 from inlet to outlet...but I'm experiencing -50 from inlet to outlet.
I have an INTERMITTENT, overheating when accelerating up hills. Happens about once a month and I drive about 3k miles a month (yea you read that right).
Fan clutch feels like its in peanut butter hot and cold
Waterpump does not appear to be leaking
Thermostat is a year old
Complete top end redone 10k miles ago.
Radiator replaced at 180k and there is 235k on it now. Ran Dex for about 30k after replacing radiator.
I suspect, a clogged radiator...Please don't answer with "Dex cool = clogged radiator"
The QUESTION is; what is an acceptable temp drop from inlet to outlet on the radiator?!
spannermonkey
Jan 10, 2013 11:33 PM
MountDisco
Defender
Aug 18, 2012 04:29 PM
gilder
Nov 8, 2009 08:11 PM
ADA110CREW
Apr 23, 2007 08:22 PM
