ACE pump dying; Can I replace it?
Old 03-04-2015, 04:57 PM
Broken08's Avatar
Originally Posted by dusty1
I can answer the bleed part.....it is a self bleed unit...(to an extent) a big open space and figure 8s or a roundabout. otherwise.......nanocom or testbook
So you're saying it will essentially bleed itself and I don't need to use a computer?
I noted today that the fluid in the ACE reservoir was totally stagnant while running. I had emptied and refilled the reservoir but I don't think the new fluid is actually going anywhere. It's been 200 miles and I think it's still the same fluid i put in sitting up there.
Old 03-04-2015, 05:47 PM
Old 03-05-2015, 06:00 AM
dusty1's Avatar
Obviously it isn't going to bleed it the pump is not working
And it will self bleed small amounts of air by itself. Not an advisable option for evacuating a complete system... Your pump should be circulating fluid
Old 03-05-2015, 06:53 AM
drowssap's Avatar
you can get a used pump for $250 with a 1-years warranty and i believe if will have to be bleed. the reason i say that is my hawkeye has a ACE bleed mode.
Old 03-05-2015, 08:20 AM
Broken08's Avatar
So, forgive me if it sounds rude, but what I'm hearing is that no one actually knows how to bleed an ace system, except maybe discomike who is MIA. And That the procedure likely involves using a computer to control things. So I'll need to have my local shop do it. And since I shouldn't install it and drive without bleeding, I actually need to have the shop do it. Is this where we are at?
Old 03-05-2015, 08:28 AM
dusty1's Avatar
I have bleed both ways. I have replaced every component of ace. Including pump and valve block . Computer bleed is best and easiest. Small amounts of air will self bleed.
But call mike, I don't know what I'm talking about.
drowssap (03-05-2015)
Old 03-18-2015, 12:31 PM
Broken08's Avatar
What computer do I need to get to bleed it?
Old 03-18-2015, 12:38 PM
Broken08's Avatar
UPDATE:
After all that, the shop was wrong. As a side project I was doing the alternator and belt. I went ahead and did the idlers and tensioner as well.
One of those was the culprit. I think the one by the ace pump; it sounded very dry when spinning by hand.
So the noise is gone! And I didn't have to replace my ACE pump. I would have been pissed if I let them do the $1300 service to fix it and it was still there, especially since it was a $20 part!
That being said, I've learned a lot, thanks all.
drowssap (03-20-2015)
Victoria
04-09-2014 09:38 AM
dev99disco
09-23-2010 04:58 PM
dev99disco
09-18-2010 08:43 PM
ljdiscovery
10-29-2009 09:47 PM
alrd
11-17-2006 11:25 AM
Quick Reply: ACE pump dying; Can I replace it?
