Activate heated windshield / seats with Hawkeye total.
Old Mar 24, 2019 | 10:58 AM
Jason_B's Avatar
Originally Posted by GCBurke
Yep those toggle to fitted....Hawkeye will do that too.
Sorry for being a bit daft here. I cannot find the toggles for these or similar options. I see the following options under the Land Rover > Discovery 2 menu.
1. EMS
2. Transmission
3. ABS
4. Airbag
5. Security
6. Chassis (the next two are under chassis)
--Air Suspension
--ACE
Anyone specifically use a Hawkeye total? Maybe I should just get the tool that you guys are using?
Old Mar 24, 2019 | 11:26 AM
Jason_B's Avatar
Ah, it was in the security menu. Neither option was toggled, I activated both and about to test it. Thanks.
Old Mar 24, 2019 | 02:14 PM
GCBurke's Avatar
After toggling them on be sure to go all the way thru the option menu to the end were you accept the new settings ...otherwise your changes will not be saved, I do have and use Hawkeye Total.
Old Mar 25, 2019 | 02:05 PM
Jason_B's Avatar
Hmm, I saw a setting for something like "Accept Loaded Settings" or something but I thought that was a reset to default?
Jason_B's Avatar
Yeah, its interested on the "Electric Seats" thing. I have powered seats and they work but the option seems like it was toggled to off so who knows.
Old Mar 25, 2019 | 03:58 PM
GCBurke's Avatar
You have to accept or nothing happens....go back in and see if the settings changed....Im betting no.
Old Mar 26, 2019 | 04:44 PM
Ben Matheson's Avatar
I've never heard of having to activate heated seats. Maybe the bcu was changed at some point from an s model? The heated windshield definitely has to be turned on. Took 2 minutes with a nanocom. And yes you must click save,approve or whatever that prompt says... Didn't save it the first time and of course it didn't work
Old Mar 26, 2019 | 06:58 PM
GCBurke's Avatar
I dont have heated seats and the setting is is set to "not fitted"
Corpraider
LR4
Apr 11, 2017 08:16 AM
MoShadeTree
Feb 19, 2014 06:28 PM
fanatic516
LR4
Jun 7, 2012 06:57 AM
lrd2
Jan 26, 2009 07:56 PM
optima
Feb 15, 2007 07:00 PM
