Add RH keyed entry to LHD DII?
Old Jul 31, 2017 | 11:43 AM
mln01's Avatar
Default Add RH keyed entry to LHD DII?
The current problem I'm having with the door lock on my truck reminds me of an idea I had a while back. Can a door lock motor from a right-hand drive truck be installed in a left-hand drive DII? You'd also need the keyed RHD exterior handle (due to the orientation of the attached lever that operates the latch rod) but if this can be made to work it would reduce the risk of being locked out of the truck if the keyless entry and the LH-only keyed entry systems failed simultaneously.
In addition to mounting the motor and handle, which I expect should be relatively easy (!) the wiring would need to be accommodated. I did a quick tour through the RAVE Electrical Library and it seems doable. I have only the LHD version of the RAVE Electrical Circuits PDF so I haven't yet been able to do more.
I'd hope that RHD motors and door handles can be found on eBay UK or eBay Australia, or from UK or Australian dismantlers.
What do y'all think? Doable? Worth the trouble? Thanks.
Old Jul 31, 2017 | 11:44 AM
Luckyjayb's Avatar
check with rimmer bros out of the U.K. They offer the package
Old Jul 31, 2017 | 11:47 AM
KingKoopa's Avatar
Really like the idea. But how far into the cab do you need to run the wiring? To the bcu? Or all the way to the drivers door?
Old Jul 31, 2017 | 03:38 PM
Luckyjayb's Avatar
I would do it. Seems like it should have some that way to start with
Old Jul 31, 2017 | 03:41 PM
Alex_M's Avatar
This is a super interesting idea. If someone goes through with it I may follow suit. I never really even thought about the locks being on different sides, or even the lack of key lock on the passengers side since I'm never over there, but this would still be a neat feature to add. May try it out down the road.
Old Jul 31, 2017 | 06:06 PM
mln01's Avatar
I looked at the Rimmer Bros site and found a Discovery 2 Central Locking page but there is no content. Do you have anything different to offer or do you recommend a phone call?
Being a tightwad I'd of course not want to buy the parts new, but others might and we all might learn something.
I spent some quality time with the RAVE Workshop Manual, Electrical Library and Electrical Circuits PDFs and it appears this mod could be plug and play. More to come on this as I spend more quality time with the documentation, take a look at the connectors in my truck, and/or call Rimmer Bros. At worst the BCU is on the RHS and we'd need to splice into two wires coming from the LHS.
Yeah, I agree, but I think most modern cars have the same setup. All the ones in my household do. The difference, of course, is that they're Japanese and this is a Rover.
Old Aug 1, 2017 | 07:24 AM
ZGPhoto's Avatar
It'll set off the alarm FYI, happens in the D1 with the RH keyed entry.
Old Aug 1, 2017 | 08:10 AM
The_OGCJR's Avatar
Oooh...good idea. I'm subscribing. Want to see how its done
Old Aug 1, 2017 | 10:57 AM
mln01's Avatar
I just came up with a far more simple, virtually free solution that I hope to test this weekend.
If anyone wants to play along think Option B. First person to figure out what I'm talking about gets Disco Mike's private phone number.
Old Aug 1, 2017 | 11:59 AM
Luckyjayb's Avatar
tie the two in together like the shuttle valve to bypass the bcu
